Remove screw ?
I'm on step 3 of the instructions for installing a new hard drive in my Powerbook G4 15" 1.5-1.67 GHz. One of the 2 12 mm Phillips screws in the memory compartment won't budge. Any suggestions ? Thanks !
좋은 질문 입니까?
좋은 질문 입니까?
Stuck screws are very frustrating!
Don't just torque on it blindly, as stripping the screw will leave you in a very poor state.
Try briefly using a hair dryer on the area to loosen things up (don't point the heat at the logic board for long, though!).
Then, with the CORRECT screwdriver size (#00), push firmly down directly into the screw and, while pushing down, turn the screwdriver.
The downward force ensures maximum drive to screw connection, and minimizes stripping.
I hope this helps!
해당 답변은 도움이 되었습니까?
use a magnetic screwdriver. Make sure you have the right size too.
해당 답변은 도움이 되었습니까?
Or get someone strong to have a go!
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 1,409
