nand error code 430
i have error ipad, cant update or restore ipad 2.
there is something error
nand 430
i googling the error code, but there is no answer at all for my problem.
thanks for helping me.
좋은 질문입니까?
nand 430
좋은 질문입니까?
I had this problem as well with my iPad 2 . After many sleepless night i finally found out it was the lcd power connector switch. Turn off the iPad and make sure the charging cable is not connected. Disconnect the lcd power connector switch straight from the logic board and reconnect the charging cable to trigger the iPad to turn , if it boots up then my friend you have the same problem i had. Replace the switch and you should be all good. I apologize ahead of time if this does not help you but i thought i would share my experience with 430 nand error.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 310
