Is the touch problem in y6 pro software problem or hardware?
The touch in y6 pro is veeeeeery bad is it hardware problem or software problem?
좋은 질문 입니까?
좋은 질문 입니까?
Enable the developer options by clicking 7-10 consecutive times on the kernel version in your "settings - about phone".
Then open the developer options - animation "off" - transition "off".. It won't secure your problem permanently but it will do for a period of time.. Note* keep your internal memory below 50% used space or else you will face some buggy software instability..
Cheers ;)
해당 답변은 도움이 되었습니까?
Protect ur screen from dirt. Keep dry then touch will be ok
Follow these steps, it worked for me ;)
1. Try to remove the cover.
2. Disable "Show correction suggestions"
3. Disable "Personilzed suggestions"
해당 답변은 도움이 되었습니까?
I have this model, I did every software solution to solve this but no change, so it's a hardware problem
해당 답변은 도움이 되었습니까?
hi my friend i did 3 steps
1. i turned off all if settings in my keyboard like suggestion
2. i did the above result “Then open the developer options - animation "off" - transition "off". “
3. I got the result and now I can type without any problem
and what happen to this phone I want to tell you about this phone I think this phone when want to use ram and CPU in its system cant type well so you should decrease the usage of ram and cpu in conclusion you turn off every related thing to keyborad and now you have a good key board thats it
thanks
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 7
30일 전: 18
전체 시간: 10,728
