iPhone not powering on
After reballing baceband ic my iphone can't turn on. I think that some component must de-aligned near the baseband and also it seems like there isn't C33 component on the board. Is it possible this to cause the problem and if yes where i can get it from?
좋은 질문 입니까?
댓글 19개
@toastedc0re post a couple of pictures of your board and your repiar with your question. Use this guide 기존 질문에 이미지 추가하기 for that. It will allow us to see what you see. Also, how did you reball the IC?
oldturkey03 의
@oldturkey03 Added an image. Inform me if you want another one, and thanks for your help!
georgekarapi 의
Can you please inform why you reballed it in the first place?
packinit 의
@toastedc0re thank you for the image. Any chance you can post one that has a bit less motion artifact? That would make it easier to identify the components
Rep: 31
oldturkey03 의
@packinit I tried to reball it with flux and a heatgun as the modem number was blank and imei didn't appear. I had tried before all the "solutions" that i found on the net.
georgekarapi 의
댓글 14개 더보기
