주요 콘텐츠로 건너뛰기
PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
387 질문 전체 보기
My PS4 Controller is dead
My PS4 controller has suddenly died on me. It wont charge and it wont turn on. I replaced the battery but it is still non responsive.
I previously used it with my Xiaomi batter back with a USB type C cable with micro usb extension. I think that caused the problem.
any solution. I basically want to know which part do i need to replace for it to work again
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 10개
It died on me but every time I charge it it vibrates
This happened to me. I thought it was the battery and also the Micro usb in put slot problem. I bring it to the support center and they said that the battery is okay and the micro usb slot is okay. It's dead and it's can't be fixed. I used my Samsung Galaxy S7 charger to charge my Dualshock 4 and it happened the next day so Please you guys out there, don't ever us any phone charger that has the out up ( fast charge ) that is higher than what the Dual-shock 4 controller require. It cause the board to burn I think and it won't ever charge again. not even alive while connecting to the USB. It's simply dead and You'll have to get another controller for 60$.
Well i was able to fix mine by changing the USB connector board and ribbon. Its easily available for 2 dollars on aliexpress. Just make sure you order the right one as there are 3 variants with different ribbon connectors .
this has happened to two of my controllers that will be $200, my other controller is dying for other reasons I was bored so one day i took my controller apart the white cord inside was all f up so I got some more but for some reason, it doesn't connect even though its the same pin cord. sony wants me to pay $200 instead of $14 (it was $14 for the wires.)
I got the controller to work but if i unplug it dies and when its plugged in there's a question mark over the battery
what do i dooooooo
You may have damaged the battery connections or the it just stop charging either try with better from your other controller and if it works order a new one , there are oem batteries with double capacity that you can get
댓글 5개 더보기
댓글 달기
답변 15개
가장 유용한 답변
I have exactly the same problem... because my battery was "dead" I decided to put it in charge with my Xiaomi power bank and suddenly my DS4 won't charge anymore !
I disasemble it and I hope it is just just the charging port/board but maybe you(or someone who knows) can confirm me ?
Thanks a lot ;)
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Yes it's the USB board , check the number and order the same one, ifixit the charges more for I yu might. Cheaper elsewhere
I change the USB port but it doesn't help. I Just test usb board and it seems fine. But I think I have an issue with a dead component on the MB, because 5V_USB and GND are shortcircuit.
I need to find which one is dead now.
I will start with the little capacitor next the ribbon connector.
But if someone got a better idea, I listen :)
thx
댓글 달기
My controller would not charge or connect, tried resetting, tried turning off ps4 for 3 minutes and then pressing ps and share button, tried another USB socket, tried another lead. Nothing. Ordered and replaced charging port and ribbon cable, nothing. Ordered and changed battery, nothing. I didn't want to order a new motherboard as is as much as a third party controller that works. In frustration dismantled whole controller, cleaned all contact points with alcohol, took opportunity to clean all dirt and grime from buttons etc. There is a small, rectangular contact point where the ribbon conductor film folds under the plastic holder and contacts the main board, cleaned both parts of the contact with alcohol. Finally in a desperate attempt I removed, cleaned and resoldered the 4 connections on the battery connection port on the main board. Assembled controller and it finally worked. Almost didn't believe it when it flashed blue. Would only recommend the soldering to someone with a fine point soldering iron tip and confidence to solder small components but it is well worth cleaning all the contacts with alcohol in case this helps and only required one additional screw to be removed. Hope this helps someone
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I would double check the battery connection, if that's ok, I would then replace the motherboard. iFixit sells them, I have included the link to the part...
DualShock 4 Controller Motherboard and Midframe Assembly (JDM-011)
DualShock 4 Controller Motherboard and Midframe Assembly (JDM-011) 이미지
상품
$27.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
If the motherboard cost $38 then why not just buy a new controller
댓글 달기
your USB port is most likely your problem. you can replace the entire board but the USB port can be fixed with some soldering experience.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It pend to me and then I play xbox in ps4 controller and I can’t play fortnite now noooooo I want to play fortnite I haven’t play fortnite for long time
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Why is my ps4 not charging it my old one and I can’t buy more because I have to pay but I not have a lot of money I only have 109£
댓글 달기
Try to install a ps4 controller driver on your pc and attach the controller via usb. And then in the device settings check if the other buttons are working. What happened to me before is that the ‘ middle PS button’ was busted so it wont turn on and I thought it was dead. And it appears to be not charging because the battery was already full.
If that’s the case, just replace the ribbon inside (it’s pretty cheap and easy to do).
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I have this problem right now. Via usb everything works even light bar, PS button as well. But it doesnt turn on at all if i removed usb cable. Battery is good. Tried the reset button hold 10 secs or 15 secs also. Any suggestion?
댓글 달기
If the DS4 no longer responds with the PS4 then more than likely it's broadcasting a normal Bluetooth signal. To remedy this, I suggest cracking the controller open and replacing the USB board/ribbon cable. And to answer another persons question as to why you'd just buy the motherboard, the motherboard at $38 is actually cheaper than a new controller, which costs about $65-70 each.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Get a charging dock my controller was dead did everythi g I could ,the I found a guy who posted about getting a chargi g dock and I did that for 20 bucks and it worked right away ...it charges from the bottom side of the controller.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yeah that's another way to go, turns out you charge th controller from the port next to headphone port
댓글 달기
Buy another controller
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
U don't deserves an Einstein name.
댓글 달기
You find something long and think like a bobby pin and reset the controller
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How can u fix the Controller sir are completely dead
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello, I think im related to the problem, as most of Us here i was charging my controller with my phone charger, (closer than console) and suddenly it turned off and never came back up again, luckily i had another two dualshock 4, one with analog drift and one with R3 not responding.. after few beers ive came to conclusion that ive seen enough TronicsFix to have basic skill/ enough experience and out of 3 of those dead boys i have made a working one…. But i had to rip off both of motors for vibration and ive realised after few days that battery dies instantly, and it really dont hold charge… im using my green camo monstrosities i dont have any other options, but if someone have solution to bad battery im happy to check it out. Thanks.!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi guys, I found these 5 tricks to know what's wrong with your dead controller. If none of these work, it's probably a problem with your motherboard.
Here is the link : https://youtu.be/I7HDa6UExQ4
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had a issue with my controller where it would lose connection and appear to power off when I signed into my account. It would function on the blue screen before the sign in. What I did to fix it was to power off the PS4 and then I held the power button until I could hear to beeps. I plugged the controller in and selected “Reset Default Settings”. This walked me through the process of setting up my controller, network and time again. No data was lost. After that my controller functioned correctly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have the solution. My controller wouldn’t take a charge. I think the micro usb connector must be damaged. So I had a cheap third party key pad for the controller that plugs thru the bottom of controller and has a micro usb plug. I charged it and it works again!
댓글 달기
It’s probably a fuse somewhere on the motherboard.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Haseeb Qamar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 10
7일 전: 34
30일 전: 231
전체 시간: 67,671
