주요 콘텐츠로 건너뛰기
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 질문 전체 보기
LCD goes black after replacing the digitizer
Hello all. I came across a problem that had never seen after replacing the digitizer of an iPad 2. The iPad turn on , the Apple logo appears , but after that the screen turns off and no image appears. The iPad still turned on as iTunes recognizes it. Anyone have any idea what might be happening? Thank you.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Have you tried to disconnect and remove the digitizer to see if screen works ok ?
From there you can tell if the digitizer causing the problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Thanks for answer, but even without the digitizer the issue persists.
Would you please check if there is anything missing around the connection on the logic board like capacitor or resistor. Sometimes when you push little to hard some small components gets broken and jumps out of the logic board .
Thanks for your time, but the iPad is OK now . A friend took it apart and reassembled it and is now working flawlessly. I don't know if he did anything else , because I wasn't around when he did it, but the most important is that the iPad is working again.
Thanks again.
Happy to hear that :)
댓글 달기
귀하의 답변을 추가하세요
Renato Sandre 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 73
