주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
LCD flickers and vertical lines
Hi guys,
my iPhone 6 recently displays vertical lines all over the screen, and I can't see anything from the OS, as the background behind the vertical lines is sometimes white and sometimes black. The lcd simply flickers and the lines jump around like crazy :)
Thought it's the LCD but even after changing the screen the same problem persists.
Everything else seems to work as intended as it vibrates on startup and also vibrates when the mute switch is activated.
I'm not sure if it connected with water as my GF was using it when the problem showed up but the LCI doesn't indicate any water damage.
Any ideas what else could cause this problem?
Thanks in advance guys
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Try to clean connectors. Usually after water damage there is a limescale on motherboard and connectors. You need to disassembly logic board and clean it in isopropyl alcohol. Do the same with connectors on LCD flex.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
thanks for your answer, I will buy isopropyl alcohol and give it a try
댓글 달기
귀하의 답변을 추가하세요
12dollar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 280
