Sound not working even after speaker replacement
Have a 6 with no sound.
Have tried the following:
-Replaced speaker
-Replaced dock connector
-Restore to factory settings
Anyone else have similar problems?
Thanks
James
좋은 질문입니까?
If there is no sound through earpiece, and headphones, then the audio IC may be faulty, but since you are only experiencing problems with speaker, I would try cleaning the speaker contacts with alcohol.
이 답변이 도움이 되었나요?
Thats not a bad shout except I have replaced both the dock connector and the speaker so the contact between the two should be spotless. I have also removed the rubber and wire mesh from the housing directly below the speaker hoping that maybe it was just too clogged up......no luck
Where did you buy the dock connector from? Also, do you have microphone and earpiece functionality? like can you call someone?
Did you manage to fix this issue? I am having the exact same issue
이 답변이 도움이 되었나요?
I’m having a similar problem with my daughter’s iPhone 6. It was dropped in a bathtub and then she continued to use it for a couple of hours before bringing it to me. Initially it was stuck in headphones mode. I disassembled and dried it out as best I could with IPA. Let it dry overnight (not long enough, I know). Reassembled and sent her to school with it. Initially the speaker was still working but it stopped later the next day. Replaced the battery a few days later and tried to clean the speaker contacts again. I have just replaced the speaker itself but there is still no sound. The earpiece speaker works, mic works, headphone jack works. Just no sounds at all from the loud speaker.
지난 24시간: 1
지난 7일: 1
지난 30일: 4
전체 시간: 134
sound works through earphones
James 의
