주요 콘텐츠로 건너뛰기
The Asus Zenbook UX31A is a laptop released in June of 2012. It is a member of Asus's Ultrabook line. It features a 3rd generation Intel Core I7 processor and a full HD IPS Display.
36 질문 전체 보기
Flickering Screen on battery power
Hi everyone,
since i changed the keyboard on my asus zenbook i noticed a strange phenomena...when running on battery power the screen is flickering almost all the time. But this only happens when i am on battery power. The screen is also very dim.
When i use the ac everything works fine, i get full screen brightness and there is no more flickering at all.
I am running on windows 10, adaptive screen brightness turned of, as well as intel hd graphics battery safer mode...latest drivers installed.
I checked all the ribbon cables and connections, everything fine so far. It would be great if someone could help me out.
Cheers
Ben
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개:
Dears
I have same issue, did anyone find the solution for it.
댓글 달기
답변 5개
Hi
If you can get into the BIOS setup of your machine, do you notice the same problem? If so, it might have something to do with the hardware. Otherwise it might be a driver issue of some sorts? Perhaps also try disconnecting the keyboard altogether. It is possible that the keyboard backlight is driven by the same power supply as the LCD backlight and a shorted keyboard backlight module is causing the ppowersupply to malfunction.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi Larry, thanks for your quick reply. I thought so and did a check with the bios running and i got the flickering as well. So it seems to be a hardware related issue. What i don't understand is why this is only happening on battery power and not with the ac plugged in...
해당 답변은 도움이 되었습니까?
점수 0
2 댓글:
Sorry about the late reply. I was meaning to get back on here!
There's a good chance that something is up with one of the voltage converters on the motherboard. The battery voltage and the adapter voltage are a bit different and when on the lower voltage, a weak converter might have trouble producing the high voltage needed to run the display.
if you're up for the task of attempting motherboard repair, perhaps you can find a schematic online and perhaps see how the power circuit is driven in the laptop.
Hi Larry, thanks a lot for your reply. I dont think i can handle a motherboard repair on this level, as i am no technician, just an experienced amateur. Do you think it will be expensive to get a pro to look after the problem?
Cheers
Ben
댓글 달기
I have the exact same problem after I opened the laptop (Asus UX303LA) so I could tighten the hinges on the display. I have looked after a new motherboard and they varry between 300 and 450 Euros. A bit expensive in my oppinion. I have updated the BIOS and of course it didn't help. The problem is obviously on the hardware side. It's a pitty since the battery was lasting around 6 hours.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello everyone. Same problem here. Was having the same problem plugged in or not. Changed the battery settings to high perfomance and now I can watch a movie plugged in atleast
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello every one, I can't say whats going on but I encountered same problem but screen would Flickr all time, then after examining , problem was in video cable.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ben Stremming 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 39
전체 시간: 9,514
