주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
MacBook BSOD after Bootcamp
Hello, my macbook keeps having BSOD after installing bootcamp latest software for macbook pro 13 2010. I have Windows 7 64Bit verison, I downloaded correct bootcamp support software(before installing bootcamp software windows worked, but there was no volume change, screen brightness, secondary click and so on) So I installed the latest available software, and once my macbook loads up, right after "starting windows" the BSOD comes up. What could be the cause? safe mode doesn't work too
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Olá . Estou com o mesmo problema , voce conseguiu resolver ? Obrigado
댓글 달기
답변 1개
선택된 답변
Hi @rockashis
Are you able to boot to mac os properly? ensure the macbook has been updated to the latest, e.g. firmware, etc from the apple software update.
are you able to get a glimpse of what the bsod says?
I would recommend you to use apple hardware test to check your computer too.
https://support.apple.com/en-sg/HT201257
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Albertas Ensteinas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 574
