Is there a fix for the overheating issues the m9 has?
Phone gets pretty warm at times . Even when the task isn't a high stress one. Thanks for the help
좋은 질문 입니까?
좋은 질문 입니까?
Actually, yes there is a way to fix it...I had actually ran across this
when I was upgrading my HTC One M9 to Android 6.0...Providing your phone is
atleast rooted, you can take a look on the xda-developers website, which I
have posted the link directly to the forum below
http://forum.xda-developers.com/one-m9/d...
Or if you dont trust url links others post online, try a google search for
"[MOD]HTC One M9 Enhanced Thermal Configuration" and the first on the list
will bring you to the xda website and straight to the form that you are
looking for...The first post will explain the installing (or modding)
process, and the 4th post will explain about the stock thermal config file
and how it is causing an overheating issue, as well as other thermal config
files to correct the issue. I read through the forum a little bit before
finally making my choice to try the "Daily Use (Relaxed)" config file. I
havent noticed any performance differences, but I have noticed that the
temperature of my phone is usually around 36-38 degrees Celsius during
heavy usage and charging using a rapid charger, I have actually seen it as
low as 28 degrees Celsius during idle, and the only time I have actually
seen my phone go above 42 degrees Celsius is when i was in custom recovery
while charging (with and without a rapid charger) and I was doing a
nandroid backup, so the android OS was not running and was not using my
modded thermal config file while in recovery.
P.S. My HTC One M9 is rooted, unlocked, and running the Leedroid custom
rom....but even on the stock rom this should correct your overheating issue
P.P.S. ALWAYS REMEMBER TO DO A BACKUP BEFORE MAKING ANY CHANGES TO YOUR
PHONE'S SYSTEM FILES. A NANDROID BACKUP IS ALWAYS RECOMMENDED AND IT WILL
NEVER HURT TO HAVE MORE THAN ONE.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 6,262
My year old HTC One M9 got hot for no particular reason and the battery just about lasted half a day. After transferring everything from the SD card to the phone's internal memory I reformatted the SD card (using my laptop) and hey presto, problem solved !
kevin.n.lane 의
I removed my SD card from HTC m9, and now it's not heating up all the time.
K S 의
