주요 콘텐츠로 건너뛰기
Repair and disassembly guides for desktops manufactured by Acer.
70 질문 전체 보기
WiFi completely gone, no networks
I was disconnecting/reconnecting wifi for a reason I can't remember. Next time it shows no networks at all and I can not connect I restart assuming it would resolve the issue but it didn't, i tried restoring it to a previous point but that also did nothing
wifi card is fine in device manager
any ideas that don't involve replacing the antenna lol? this is all in one machine and a night mare to repair
thanks all
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Does it "see" any wifi networks and can you see the wifi status symbol in the corner doing anything? What model is your PC, what OS are you running, and is the wifi card aftermarket?
댓글 달기
답변 3개
가장 유용한 답변
Hello David F im my opinion it could the the drivers of the wifi are corrupted this is not a 100% sure that could be the problem but since you say that is a all in one Desktop I really dont trust AIO PC.
You could download this free Legal program that will install 100% updated new drivers (driver park solution)
https://drp.su/index.htm
This could fix your problem with the wifi driver
HOPE THIS SOLVE YOUR PROBLEM :D
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
i will try thanks
댓글 달기
Open Network and Sharing center
On the Left click "Change Adapter Settings"
Right click on one of the devices/options on the right hand side and make sure that they are enabled!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Just put a bit of vinegar on it pet !
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
David F 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 591
