Phone shows no life
Had my phones LCD replaced a couple of days ago. Phone lasted about a day working fine then it just went black. tried all the resets etc. took it back into them, they held onto it for a day and told me everything looks perfect inside the phone. they have tried new batteries, lcd etc but nothing works. phone is showing no life whatsoever.
any clues as to what it could be? and would it be the stores fault? (could they have damaged something)
please email me if you have any helpful info!
Thanks in advance
좋은 질문 입니까?
what caused the display needing changed? Did you drop the phone or get it wet?
Is it possible that the repair shop did something? Yes. Is it likely? I would not be able to answer that without seeing the phone. Its much, much more likely that you dropped your phone or got it wet, which damaged the internal components. The display going bad was just a symptom and the root cause was the damage done to the board.
Josh W 의
