replace a a1212 with an A1261
hello, I have a macbook pro with the logic board a1212 broken , I would like to know if i can replace it with a A1261 (to have such a powerful pc).
thanks
좋은 질문 입니까?
thanks
좋은 질문 입니까?
No sorry they are not cross compatible , for starters the screens are different a1212 uses CFL bulb , while the a1261 uses LED bulb.
해당 답변은 도움이 되었습니까?
thank you, and whit a1229?
or any more powerful?
A white screen usually indicates a failed hard dive. Try disconnecting the drive from the logic board and booting from the original system installation optical disk.
해당 답변은 도움이 되었습니까?
you are right, thanks a lot!!!
Then you accepted the wrong answer ;-)
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 140
댓글 4개
or another more powerful, as the model a1229
davidegatt 의
Why do you think the logic board is broken?
mayer 의
the screen remains white after power, and did not work any recovery procedure (pram reset etc.)
davidegatt 의
davidegatt 의
