Fixing the setting dial on washing machine
There are 2 parts to the dial: one part (1.) that seems to be the dial that actually controls the setting, and the other part, underneath, (2.) that has the arrow on it that points to the setting. The second part can be accidentally turned independently from the first part, which is what caused the problem. The part with the arrow turned so it does not point to the right place in the cycle. The manual doesn't cover this that I can see. I need to know how to fix the dial so it points to the right place, and if possible, so it can't get knocked off again. (Possibly by removing the second part of the dial?)
좋은 질문 입니까?
댓글 4개
Here's how to add images: 기존 질문에 이미지 추가하기
mayer 의
Thank you for the tip!
selkie305 의
Please check that number as it brings up a microwave oven.
mayer 의
That's weird. It's the number that's on my washer. And I had an online chat with GE about it, in which they sent me the manual (good, but no help for this issue) and then told me to have a repair person look at it. It just seems like the kind of thing I should be able to do myself, as nothing seems to be broken.
selkie305 의
