주요 콘텐츠로 건너뛰기
Repair guides and support for netbooks produced by Asus, including the Eee PC line.
How to remove ASUS TP300L battery?
I tried to move the battery but I couldn't
This is a picture for it
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
the battery is held by screws, you have to remove them all
check the image attached
remember to remove the battery terminal (connector from the board)
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
I did do what u told me but u can see that there is small wires attached to the battery below in three colors red and white and black I couldn't remove them
that's the connector... u should hold the wires and pray (pull upward) with little pressure..
if you still have difficulties pls take another clear picture showing only the connect (the three wires side) so i can view clearly how it looks like .
I have done the same thing. But after that what should I do? My computer seems not to on. green light appears in the sign of the battery when I plugged in the charger. I have press the power button for 30sec and no effects shown. Please help. It's any other way to save my files in it?
If you just plugged in the new battery you may have to wait like 15-30 minutes to an hour with the computer plugged in with a charger for the battery voltage to go up high enough so that it lets you turn the computer on. Not all new batteries come with enough charge to turn on the computer.
about your files @vic ... if you are so concern about the files not the machine they are completely safe in the HDD unless the HDD is damaged or encrypted with pw and forgotten if not even if the machine is dead you can pull out the HDD the another pc and get access to you files
댓글 달기
To unplug the connector you have to push it upwards from the sides with a flat screwdriver
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
iseham altamimi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 5,168
