주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Touch ID not working after screen replacement!
Hi everyone, I have iPhone 6 and my screen was broken after I replace it with a new one the touch ID stopped working.
when I go to "Touch ID & Passcode" it's looks like I have never set a touch ID before, when I try to make a new fingerprint it says " Failed, unable to complete Touch ID setup. Please go back and try again."
everything with the home button works.
I updated iOS and try to reboot iPhone
also I go back several times to check on the home button cable all is good.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 24
댓글 2개
how to failed unable to complete touch id setup please go back and try again
Yesterday , i change my battery after than my touch id cannot working, phone show unable touch id. The problem issue is from my battery or not ? How i want ro solve it
댓글 달기
답변 18개
가장 유용한 답변
If you get this message - " Failed, unable to complete Touch ID setup. Please go back and try again."
Then all you have to do is plug your phone into computer, once itunes is opened, put your phone in DFU mode and reset your phone. The phone must be in DFU mode.
해당 답변은 도움이 되었습니까?
점수 15
댓글 23개:
Will dfu mode delete all my pics and everything??
Yes it will!
how do you put phone in DFU mode with itunes
Thank you much. It worked :D
Hi, Please I did not change my screen or anything close to that but I get the same error. Help pls
댓글 18개 더보기
댓글 달기
Did your replacement screen come with a new home button on it? If so, you need to transfer the original button back to the new screen. The home button and motherboard are "married" from the factory. If you change the home button, touch ID will cease to work. The rest of the functions will remain intact. I don't know why some suppliers preinstall new home buttons, it only creates problems. Used to worse though. If you dont believe me just Google "error 53."
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
no it's not, it's only a screen replacement all other parts is original. I'm afraid I broke home button connector, but the home button works fine except Touch ID
Try reseating the home button one more time
If the touch button is defective just transplant the chip from the original home button to the new button. This will require you to remove chip and re ball it
I did not change my screen the screen protecter broke and I remove it phone was working ok now this message pop up
댓글 달기
If your iPhone is iOS 10.3.2 and is showing u unable to setup Touch ID the only solution is to update it to IOS 10.3.3 believe me this worked perfectly for me
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Not always the case. logic board is paired with the button from factory. Best thing to do is use same button or transplant the IC from the old button to the new one.
댓글 달기
It worked like a charm bro
very very thankx
1.delete a finger configuration
2.turn off *iphone unlock
*itunes &App Store
3.Hard restart by home and wake up buttons...
bang
Id starts working
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
i had mine replaced too, it was iphone 6s. the guy didnt replaced the home button, but when i got mine after replacing it, says "Failed, unable to complete Touch ID setup. Please go back and try again." im starting to panic . my bf told me to just reset my phone maybe it will work. I pressed and hold the wake and home button together for 3 seconds until apple logo appears, didnt worked at first. after 8 hours, im still hoping it will work again so I tried for the second time and it worked ! :D it just takes a lot of patience to wait until it works again. try and try , but not waaaaaay to many times your phone might get rid of you . lol :)
i hope this one helps.
but i suggest never to let your screen replaced by third party.
댓글 달기
Touch ID is paired with the board. You have to have apple pair your new Touch ID with the board or transfer your original Touch ID back. iPhone 6 Home Button Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have the same issue. I was deceived by a video on YouTube ‘how to change iPhone home button ring!’. I just tore down the home button so to change the ring from silver color to gold. After an attempt I just thought it might be dangerous! Then, I reassembled it and every part is intact, but shows the same message.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Transplate chip from old button to the new button. Chip is paired with the logic board. Sounds like the ribbon may have gotten ripped.
댓글 달기
Check the flex which connect the home button to pcb
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Unable to complete Touch ID setup please go back and try again
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
The thumb button is its own chip, most likely was left unhooked or broken during the glass swap, i did a swap on one i had before and the face cam didn’t work and the sensor to black the screen on phone calls didn’t work so i just took it to apple for warranty lmao.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I replaced my screen and transferred the home button, but the Touch ID failed to be recognized after the replacement. A month later I had to replace another broken screen and transferred the home button again. Everything worked including the Touch ID with this 2nd new screen
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
This could be due to a rip in the flex cable of the home button. In order to keep touch ID you would need someone to microsolder jumpers on the home button to repair otherwise you will only have home button function on certain devices. If the device is 7 and above you would need a special home button to keep the home button function.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
HI
Check that using wrong screws or not , there are 3 pics the shortest screws on the mainboard
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hey Ibrahim Alayaf, I have this issue before too and what I did was erase all contents and settings. After I reset settings. Please see here for instructions: http://www.technobezz.com/iphone-ipad-to...
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
hello some screen replacement for iPhone 5s to 6s plus the touch id work after 24hrs but if this not work maybe your screen not compatible with your touch id home button. i hope this would help you.
Hi Ibrahim,
have you solved this issue in the end? I too have the same problem.
Thanks
hv the same problem it says couldnt complete setup
댓글 달기
Unable to complete Touch ID setup Please go back and try again iPhone 6
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I never changed my screen but it says unable to complete Touch ID
what can I do?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Google pay not working
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
The latest upgrade in IOS has appeared this bug, I hope they will fix it soon
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
Ibrahim Alayyaf 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 35
전체 시간: 157,805
