주요 콘텐츠로 건너뛰기
The Dell XPS 15-L502X laptop was manufactured by Dell Inc. It was released in 2011 with a 2nd Gen Intel® Core™ processor.
Annoying sound and overheating
How to fix the annoying sound and tends to heat up quick after just around 2 hours of usage?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Are the internal fans spinning? Did you clean the vents on the unit?
What is the annoying sound. Do your hear a ticking sound or do you hear the fans rev up to maximum speed ? Something is causing the laptop to over heat. I agree with Brian on his suggestion. Do you see any dust or lint blocking the air vents ? Do you notice the bottom of the laptop getting hot ?
댓글 달기
답변 1개
가장 유용한 답변
How old is it? Older laptops tend to clog up their heat-sinks with dust causing them to overheat and make the fan spin faster.
However, if you hear the fan actually grinding the bearings in the fan might also be broken. If this is the case, you need a new fan.
For the dust issue: The best solution is to open it up and clean the dust out yourself.
However this does require some work and is semi risky depending on your technical skill.
https://www.youtube.com/watch?v=AD5jpqVo...
If you dont want to do this, you can also try to get some compressed air and and blowing it into the air exhaust to get the dust loose.
  • Warning: Do not blow for more than a second in a row, the air will cause the fan to spin too fast and break.
  • Warning 2: Do not hold the compressed air can upside down. while spraying.
  • Warning 3: This solution is only temporary, you are going to have to open it up and clean it eventually.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
testoutjian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 13
전체 시간: 753
