주요 콘텐츠로 건너뛰기
LG G4는 늘 그렇듯이 고급 사양과 세련된 패션 감각을 강조하여 프리미엄 스마트폰 시장에서 눈에 띄는 제품으로 2015년 6월 초에 미국에서 출시되었습니다. 이동 통신사에서 판매하거나 잠금 해제 (미국 또는 국제) 된 휴대폰의 각 버전에 따라 모델 번호는 다릅니다. 일부 LG G4에 부팅 루프 문제가 있는 것으로 알려져 있습니다.
replacement battery does it nerd to be charged?
do i have to charge a replacement battery?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
In most cases replacement batteries have around 40% charge or possibly lower depending on how long and the environment it is stored in. So normally it should not need to be charged immediately to power on the device. If you have received a battery that has had a longer shelf life it may need charged. If it has sat for a long period of time before you received it than it may read at zero volts with a multimeter. This is due to a protective circuit in the battery. The protective circuit will put the battery in a sleep like state if activated. It helps protect the battery from overcharging, discharging, to high or low of temperature and other factors that can damage a lithium ion battery. The battery can be awoken by supplying it with a boost charge which supplies the battery with a higher current to bring the battery out of the protective mode. Once the battery is woken with a boost charge you then finish charging the battery with its normal charger. I personally would return a new battery if it has no charge rather than trying to boost charge it, because it has likely had a long shelf life or been stored in a poor environment.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Denise Kearney 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 151
