주요 콘텐츠로 건너뛰기
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 질문 전체 보기
Black LCD then no light
I dropped my Ipad mini last morning and at first it turned black, and after a few shake it turned back, while using it my ipad turned black with light so i decided to restart it by pressing the start and home button at the same time... and after a few try i noticed my ipad mini won't work... there is no light on it, I tried to charge it but the battery logo won't come out. What should I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Most likely the connector came loose when you dropped it, or you damaged the LCD in the fall. You'll have to take it in for repair at a local shop, or get the parts here on ifixit and follow the guide and do it yourself.
Make sure you get a digitizer too if you do it yourself. Even if the glass isn't broken, you'll likely destroy it in the removal process.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jec Tan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 42
