주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HD action camera with touchscreen LCD, released October 5, 2014.
Should I replace Motherboard?
Hi all,
My camera is not charging or responding to anything, either plugged in into a wall charger or laptop ect.
Background:
I believe I damaged the motherboard by charging it with a crap usb charger (output of 5.35V). It smells a bit like burnt electronics and it heats up if I connect it to the power. Even with no battery, the camera does not respond. I have tried other batteries so that is not the issue. I have tried other cables and is not the issue either.
The camera is out or warranty and GoPro support wont even try to look at it :(
The Question:
I believe that the charging circuit/voltage regulator is part of the Motherboard. However, I am afraid that this would not solve my problem (ie. may have damaged other parts of the camera). I am an Electronics Engineer and I am able to replace the board.
Just wondering if someone has done it before or had similar issues??? I do not have a schematic to diagnose the fault so it is a risk if I decide to replace the motherboard and it does not work....
Thanks for taking the time to read this
Cheers
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Here's the guide on replacing the logic board: GoPro Hero4 Silver Motherboard Replacement
Here's the part: GoPro Hero4 Silver Motherboard
Replace a corroded, damaged, or malfunctioning main circuit board assembly. This part is compatible with the Silver Edition of the GoPro Hero4. 이미지
제품
$54.99
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Hi guys,
I have a similar problem. I did purchase a new mobo and followed the replacement guide to no avail. My Silver still won't turn on.
Do you guys have any idea what else could be the problem?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Novice RC 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 737
