주요 콘텐츠로 건너뛰기
Mac Pro First Generation는 Apple Inc.이 제조한 Intel Xeon-기반 워크 스테이션 컴퓨터입니다. 2006년부터 2008년까지의 컴퓨터가 1 세대 모델에 포함됩니다.
317 질문 전체 보기
Mac Pro Runs all Day and gets Hot
I have a Mac Pro with two additional 500GB 7200rpm SATA drives that are RAID1. That I believe is what is raising the temp. Is there a fan or other means that can be mounted inside the MacPro that can cool things off? Suggestions welcome.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Hi!
I'd absolutely start by getting three cans of air, taking it outside, opening it up and blowing it out. Swap out cans as they get cold. You may need to leave the cans in the sun for a bit and start over.
Now we need to try to figure out why it's getting hot. Fire up your activity monitor (Applications -> Utilities) and watch what's going on with your CPU(s). You can click the "%CPU" to sort by what program is loading your computer. Something fun like SETI@home would cause your symptoms nicely.
Another thing you can try is watching your temp. sensors. The program I linked can show you everything that's being monitored by your computer. It might let you pinpoint what's making the heat.
If you think it's the two drives, turn your computer off after it's been on a couple hours, open it up and feel them. If they're too hot to touch, disconnect them and fire it back up for a while. See if the heat problems drop or not. If they're the culprit, get some firewire 800 enclosures for them. Since you're running RAID 1 you probably won't notice the speed hit and your drives will live longer. Yes, OS X will let you raid externals.
Good luck!
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
댓글 달기
Here's
a place with RAM coolers
You could also try:
  • Dusting inside,
  • changing/customizing airflow (ducting heat away or cool air in - maybe using an external fan)
  • common sense (don't put it in a corner, up against an obstruction, near other heat sources, e.g. sunlight)
  • add a VGA fan cooler
  • Software to run fans longer or more often (runs the risk of burning out the fans)
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ki4tjy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 2,810
