iPhone 6 Battery Draining while phone is off.
Hello, I am having an issue with my iPhone 6 Battery and am looking for some help. After replacing the battery and the charging port my battery appears to be draining while the phone is turned off. I will go to sleep with battery at 100% and turned off (holding the power button and sliding my finger across to turn it off not just standby) and I will wake up in the morning and the phone will not turn on and will require charging again. Anyone have this problem before or a similar problem?
좋은 질문 입니까?
댓글 3개
When using it, how long does the battery last?
Gigabit87898 의
the other night i used it for about 4 hours watching hulu and it drained from 100% to around 50% its not a phone we actively use in the house as we have replaced it and mainly only use it for apps now.
Thomas Hurta 의
Why are forums the place to ask irrelevant questions? How fast it drains in use won't help diagnose problem. There is clearly a short in a circuit. Question is how to test when the phone is off? I don't know. I would look for a conductor between battery & case & I believe most likely would be moisture. Just a guess.
fm Haynie 의
