주요 콘텐츠로 건너뛰기
Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
60 질문 전체 보기
Can I fix my severed cable?
Hi guys.
Today I managed to snap my headphone cable in half. The headphones in question are the B&O form 2i. Iv looked around the forum but my problem is unique as the cable has snapped exactly where the cable from the right and left speakers join into one cable.
How could I fix this? Please help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
First remove the little plastic piece where the connections split. Strip both ends of the wire, and on the end with the jack, use a multimeter on continuity mode to figure out which wire is left, right and ground. You may have to melt off some of the insulation first.
http://wiki.robotz.com/images/6/6c/Trrs-... (ignore the ipod video thing, it is irrelevant in your case.
On the end with the headphones, solder the ground wires from each ear to the ground of the jack, and left to left and right to right. Then test your wiring with this vid
https://www.youtube.com/watch?v=hTvJoYnp...
After you are finished, insulate the connections with electrical tape and hot glue it together.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
It all okay! I simply cut of the rubber insulation and joined the wires by simply twisting them around each other and insulating them with electric tape. I even managed to get the controls to work (the mic should work too but I have yet to test it).
댓글 달기
귀하의 답변을 추가하세요
Imad Knight 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 993
