주요 콘텐츠로 건너뛰기
2013년 7월에 출시된 경제적인 Samsung Galaxy S4 버전입니다.
99 질문 전체 보기
Why can I get no network access
Hi, having just repaired an s4 mini, which is locked to EE, I've put my normal EE sim card in the phone, but get no network access at all. When the sim is in my other Samsung, there is a good signal. Does anyone have any ideas what the problem could be? I can save contacts to the sim card, so I think the sim reader is ok. Could it be an antenna? or is there another part that could be at fault.
Many thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 6개
Are you on the stock software?
Hi Ethan, yes. Standard software.
By no network access, do you mean that you don't get a signal, or it gives you an error when trying to call someone
Actually both. Circle with a line through it at the top of the screen. If I try to make a call I get a message saying there is no network connection.
Hmm do you have all the required antennas properly inserted?
댓글 1개 더보기
댓글 달기
답변 1개
선택된 답변
Hey Bigphilly71,
I would recommend you contacting your provider, maybe they can help you! Also, check your motherboard if everything looks alright.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bigphilly71 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 501
