Can my 1.5Ghz SoloCore be upgraded to a DualCore processor?
I have a new optical drive,
will increase the memory
put in a little larger drive in place of the original 60GB unit
좋은 질문 입니까?
좋은 질문 입니까?
I have upgraded my Mac mini T1200 1.5GHz Core Solo to a T7400 2.16GHz Core 2 Duo with absolutely no issues. The new processor runs a little hotter than the original. Mine has been stable with the upgrade for over two years.
해당 답변은 도움이 되었습니까?
Yes, Mayer, that will also work fine. I have upgraded two 2006 1.83GHz 17" Core Duo iMacs to 2.16GHz T7400 Core 2 Duos with no issues. The performance increase is significant. The performance difference between the 1.5GHz Core Solo and the 2.16GHz Core 2 Duo is out of the park.
So far it'd doing fine. Here's the actual benchmarks of before and after: Core Duo CPU upgrade to Core 2 Duo CPU?
I think you can. All the way up to a 2.33 GHz Core 2 Duo T7600. I upgraded my Core duo 1.83 to a Core 2 Duo 2.0 Ghz.
해당 답변은 도움이 되었습니까?
That was a simple upgrade within the same model.
But isn't the Core Solo within the same A1176 Model line? I think it is. Just look on Ebay for the following processor numbers: T5600 Core 2 Duo 1.83, T7200 Core 2 Duo 2.0, T7400 Core 2 duo 2.16 and the aformentioned T7600. Just follow the guides in here for CPU replacement and you should be in luck.
Just look here: http://www.macintouch.com/specialreports...
해당 답변은 도움이 되었습니까?
+ interesting upgrade and good link. Not something for an novice to try.
change cpu is difficult (to delock the radiator of the cpu
T5600, T7200, T7400, T7600
I upgraded a Core Solo 1.5GHz with a T7600 Core 2 Duo 2.33 GHz. The guide here on ifixit is well done, and along with the notes on each step, it was all I needed to do the work.
I would say having the proper tools helps a lot. Who knew a spudger was so important :)
Gary O'Brien
Photographer
Charlotte, NC
해당 답변은 도움이 되었습니까?
There are no CPU upgrades for your machine: http://www.welovemacs.com/apmacmi1inco16...
해당 답변은 도움이 되었습니까?
This answer may be incorrect. I'm going to try upgrading a 1.83 GHz Core Duo tomorrow to a T7400 2.16 Core 2 Duo. Will also be running xbench to tell if it's worth the trouble.
The upgrade worked great.
To who ever downvoted this with no explanation. Some answers change as more knowledge is gained. RAM configurations, hard drive sizes and upgrades all do. We live and learn and advance. My original answer was correct when given and changed as time went by. Which part of the answer should I change to suit you? Which part are you downvoting?
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 6,885
