주요 콘텐츠로 건너뛰기
2013년 7월에 출시된 경제적인 Samsung Galaxy S4 버전입니다.
99 질문 전체 보기
Phone cannot turn on, cannot charge and is recognised as a USB
I was on my phone watching youtube, then the phone went black screen and turns off (its normally usual to do that on my phone) but normally it would reboot... this time it didn't. I have used both batteries, above 50%, i have also tried charging the phone without the battery. The phone will not react, no LED or nothing. This problem happened once but it later turns on. The phone won't restart, go in command prompt or factory reset. My phone is rooted so I have no warranty. What can I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
What do you mean when you say it is recognized as a usb? Also is it drawing the correct amount of amps from the usb port?
댓글 달기
답변 1개
I guess it could be irreparable, if there is no Liquid in the Phone it cold be that the Logic Board is Broken or any of the Connectors / contacts on the Board is damaged. In this case you have to search on the Logic Board or the Smaller Board with the USB Connector to find the Broken Connector and Soldering it. But this could be quiet difficult.
The other Option ist that the Software is damaged but i guess it should even start or let you do a reset or something else.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
qnoel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 108
