주요 콘텐츠로 건너뛰기
모델 PowerBook 1400 Series. 1996 10월 출시
8 질문 전체 보기
PowerBook power on woes yet again!
I just replaced the PRAM battery of a touchy PowerBook 1400cs/133, and finally see the green "power" light glowing. I decided to leave it charging overnight to let it get some power, and this morning tried powering it on. The PB doesn't seem to be responding still, and I hear no noise or anything of the sort.
All connections to the mobo are connected properly (VGA, speaker, trackpad, keyboard).
Resetting the PRAM battery doesn't seem to be making much of a difference. The green "power" light keeps glowing, even when the charger is disconnected or the battery is pulled from the PB.
Does anyone have any ideas what could be causing this power oddity? Resetting the PRAM battery via the switch in the back isn't making much of a difference. Should I declare the PB a vegetable or brain dead and send it to the junk pile, or is there a chance of bringing it back to life?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
My 1400 starts every time when I hit the small reset button on the back, the tiny button between the two inputs on the right.
댓글 달기
답변 2개
선택된 답변
Try resetting the PMU. Here's how to do it on your machine: http://support.apple.com/kb/HT1781
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
I've tried that. It's not making a difference.
Perhaps there may be something else at hand here?
It's been a decade since I worked on one. Try pulling the battery and starting from the AC only. Check the AC adapter with a voltmeter.
Pulling the battery didn't work, either. I'll have to go dig out my voltmeter. Hopefully if it's just a bad AC adapter, then that'll make the rest of the fix easy enough... I just get another one! :)
Been a long time for me also. +
댓글 달기
Have you tried pulling the PRAM battery out and then starting up? This worked on my PowerBook G3 Pismo AND it worked with my PowerBook 3400. After the initial start up I can boot up without any issues, however I had to do this to both of them.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
LambdaCalculus 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 6
전체 시간: 1,692
