주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
328 질문 전체 보기
Black Screen, MacBook turns off and on randomly
I have tried shutting it down and restarting to reinstall the software but the screen still comes on black and turns off a few seconds later. If there is any work to be done on it I would like to do it myself, so if you can help me that would be great.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
muchonice,
I'm sorry to hear you are having an issue with your MacBook Air. A friend of mine had the same issue. Was able to use it, but would should down at random times. Replacing the Logic Board fixed the issue. I believe the main issue is the GPU overheating for some reason. I would recommend taking it to the Apple Store and setting up a Genius Bar appointment.
Here is the link to get started- http://www.apple.com/retail/geniusbar
I hope this helps!
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thank you for your help. My problem has changed. My screen is now black and stills turns on and off on its own.
Oh my goodness! I am so sorry! I would definitely take it to the Apple Store for them to Diagnose it. Two things you can try before going is reseting the NVRAM and SMC. Here are the links on how to do this -
https://support.apple.com/en-us/HT204063
https://support.apple.com/en-us/HT201295
댓글 달기
귀하의 답변을 추가하세요
muchonice 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,861
