주요 콘텐츠로 건너뛰기
iPad 2세대, Wi-Fi, GSM 그리고 CDMA 모델이 있습니다. iPad 3 출시 전에 일부 모델을 새롭게 하였습니다. 수리는 어렵고 열과 비집기가 필요합니다.
730 질문 전체 보기
Could heat from heat gun misalign Home button and data port?
After a 3rd attempt everything went smoothly or so I thought I used a low setting heat gun as instructed in a video to seal the adhesive, I may have gotten too close to the power/data port and home button, because after 4 hours of waiting for the adhesive to bond I started to notice first that the Home button didn't respond, I tried to reset settings no luck, and then I found when I plugged it in it won't charge unless pressure is put on the screen near the port like in this video https://www.youtube.com/watch?v=c5damnSS... but much worse, the home button does respond when pressure is applied, is it possible the heat unseated the board or worse yet bent it somehow with the heat? Am I pretty much screwed and now need a new logic board or do I just need to reopen, seat the board correctly and close up with new adhesive? I forgot to say everything else works fine. Upon further inspection it did not seal properly I can see visually that it appears the area of the button and connector is not in alignment. The bezel is still good so I can reuse, after applying pressure again it is now charging, obviously this is long out of warranty so I can't get a replacement, I'm using an assistive Home button at the moment, it can limp along like this but would be better if it worked the way is supposed to. Please tell me what you think is wrong.
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
I wouldn't jump to conclusions like the logic board being at fault before trying to replace the cheaper components such as the charging dock and the home button assembly first.
You can get the home button assembly from here:
iPad 2nd and 3rd Gen Home Button Assembly
You can get the iPad 2 dock connector here:
iPad 2 Dock Connector
Guide to replace home button:
iPad 2 GSM Home Button Assembly Replacement
Guide to replace dock connector:
iPad 2 GSM Dock Connector Replacement
iPad 2 Dock Connector 이미지
상품
$19.99
iPad 2nd and 3rd Gen Home Button Assembly 이미지
상품
$12.99
iPad 2 GSM Dock Connector 이미지
안내서
난이도:
어려움
iPad 2 GSM Home Button Assembly 이미지
안내서
난이도:
매우 어려움
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I really don't think replacing those parts is going to do it, seeing how with applying pressure they both appear to function, I'm more inclined to believe the board was affected when the heat was applied.
댓글 달기
Heat can cause the plastic in the charging port to warp which sounds like thats what happened here as now you can not fully insert the charging port to charge the unit. Unless you put pressure on it.
Did you get a new screen with adhesive and a home button already on the new screen? Or did you transfer the home button to the new screen?
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Yes it's a new screen with adhesive and a home button already on it, so then it could have possibly warped the home button as well. That would make sense, given the pressure needed to make them work, I still have a home button from a previous screen I could try, but I would have to get a power port replacement, I guess I will have to try that and see what happens. Thanks for the answer. I just need to clarify the I can insert the plug fully into the charging port but it takes the pressure for it to charge.
댓글 달기
귀하의 답변을 추가하세요
Ken 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 3
전체 시간: 124
