주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone keeps restarting when on charge
Whenever I plug my iphone 5 into charge the apple logo keeps appearing then it'll restart and the apple logo appears again this process is repeated over and over. I've been looking around various forums and found that people suggest rebooting your phone in itunes. However my iphone 5 is completely out of charge and the usb port in the computer doesn't have enough power to start the phone, so i have no way of connecting it to itunes. Any help would be appreciated
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Try to unplug the battery and turn it back .or maybe your using a third party charger thats why you made your charging port/battery misbehave .Replace the battery or just try it remove the battery turn it back plug the charger and see if it works hope it helps
i fixed mine.. it has been restarting since this morning and it don't even charged. i decide to open the batery and put it back..hola! it charged and restart loop has gone..
댓글 달기
답변 4개
선택된 답변
Try cleaning the charger port with a toothpick or something equivalent if the charging port does not plug in fully.
This can also be caused by liquid damage on the charging port area or even logic board components.
I would try another charger port if cleaning the charging port dock assembly does not fix the issue.
Guide to replace part if needed:
iPhone 5 Lightning Connector and Headphone Jack Replacement
You can buy the replacement part from here:
iPhone 5 Lightning Connector and Headphone Jack 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
I have this problem after I replace the lightning connector and headphone jack
댓글 달기
I had the same problem. What I did to resolve this was reset the phone. When the phone started to reboot with the Apple logo screen, I pushed the home button and power button for 10 seconds. This shut the phone down and allowed the battery to charge a bit until it could fully boot.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hey Timothy McGuinness,
I think it's your battery, you should replace it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I've replaced the battery but it still have the same problem of no charge
Maybe the charging port?
댓글 달기
Hey Timothy, sometimes applications running in the background can cause your phone to restart abruptly. I would advise you to close suspicious apps. You can read the full instructions here: http://www.technobezz.com/iphone-ipad-ke...
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Doubt it. When it is plugged in, the reboot loop issue occurs.
how if we can't get to the home screen...
댓글 달기
귀하의 답변을 추가하세요
Timothy McGuinness 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 31
30일 전: 162
전체 시간: 14,375
