주요 콘텐츠로 건너뛰기
Repair guides and support for netbooks manufactured by Compaq.
18 질문 전체 보기
My computer Loss the power after 2 min when charger is pluggged
Computer is working fine when it is in on battery, but when I connect my charger my laptop is loss power(off directly) after 2 to 5 minutes.
Already i check my adapter it is OK, with other adapter same problem occur.
Also i check my power supply of my house no problem was there, It is happen in other home also.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hello,
probably you will have a bad connection in the laptop. Try to replace the DC jack. or try with an other..
If you know enough about electronics, you can try to measure out the PCB connecting your dc tot the main board. I had a same issue to an older model of acer. it was a bad connection in the PCB.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Anup Pasari 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 68
