주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 기기는 Samsung Galaxy S II의 T-Mobile 버전입니다. 2011년 10월에 출시되었습니다. T-Mobile의 새로운 확장형 4G 네트워크를 지원하는 최초의 Galaxy 기기였습니다.
Where can I find the original operating system
I downloaded a third party OS but now I have to get rid of it so I can pass my old phone along Unfortunatly I did not back it up though. does anyone know where I can find the gingerbread OS and how you would restore it? Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Here is my source and hopefully this helps. Make sure to download any available updates for your phone after the factory reset.
''This are the step by step procedures on how to factory reset or hard reset the Samsung Galaxy S II, to return the phone to its original factory fresh default settings.
This may help and only advisable if experiencing frozen or hang up problems when using or opening some applications you previously installed on it.
Take note this will delete all data from the Samsung l9100 Galaxy S II as a result of this procedure. This process may or may not delete the data stored on the microSD memory card. Ensure to make a back up a copy of all important data before proceeding.
First do try to factory data reset the phone through the main menu settings.
1. On the main home screen, just select MENU
2. Select SETTINGS, then select PRIVACY
3. Select FACTORY DATA RESET
4. Select RESET PHONE
5. If the password is required,enter it. Then confirm by selecting ERASE EVERYTHING
IF the phone is hang up or frozen, Try to turn it off first and do a hard reset through key combinations.
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
Wait 'till the process completes, Once the wipe is completed, the Samsung Galaxy S II l9100 will then reboot. All the data you previously installed already been deleted and then the phone will then return to its original factory fresh default settings.''
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Sammobile website and always use latest original Samsung firmware.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Both would be great answers but I'm not looking. To flash new firmware and since I have a custom operating system all a factory reset does is reset my custom os I'm looking for a place to download either marshmallow (my preference) or if need be jellybean thanks
custom ROM, you find it on XDA developers then. Cyanogenmod 13 / 12.1 / 11 preferably
댓글 달기
답변을 추가하세요
Jonathan v 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 14
전체 시간: 459
