Why is my battery not charging.
My hdx 8.9 will not charge.
initially it would not charge when hooked to the cable. Even after changing the cable and light jiggling of said cable. Eventually I got it to charge to 6% before it just stopped charging again. I turned on the device got tech via mayday. But then I could not turn the device off. When the batterywent out I tried charging it again with no result. BUT now on can't tell if it's not charging or the darned power button won't work.
좋은 질문 입니까?
댓글 2개
I'm having similar problem except the battery seems fine but it's stuck on Kindle Fire screen all of sudden. The battery is covered with Stainless Steel cover but managed to unplug and replug then turn back on and still froze on Kindle Fire screen
Please help
Mike Russo 의
This is a common problem. You can follow the steps given in this guide to fix this:-
http://www.howali.com/2017/05/my-kindle-...
tony 의
