주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
Boot loop after screen replacement
I have a friend's iPhone 5c and I changed the screen out for a replacement. I have done this several times on different phones with great results. This time the phone displayed a few lines of [NAND] dialogue, with the message "s_cxt_boot:88 sftl: error, unclean shutdown; adopted 863 spans". I found a blog saying to try replacing the frontcam/sensor flexcable, and the frontcam/sensor connector at the mainboard. I have replaced the first part, but cant find any instructions to do the latter. I have another phone that works, and could simply put the new screen on the other phone, but she has never done any sort of icloud backup and doesn't want to lose her stuff. Can anyone direct me?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi Jessica!
Yep, often error like these behave from an hardware error. This is the guide you need:
iPhone 5c Front-Facing Camera and Sensor Cable Replacement
A test you can do before buy any replacement is to disconnect, in this case, the front camera / sensor flex and without close the phone, try to boot again.
If the problem still continue, try also to disassemble the shield that hold in place the display assemble cables.
Cross my fingers for you..
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have replaced the front assembly. I need a guide for changing the connector on the mainboard.
댓글 달기
답변을 추가하세요
Jessica Paradis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 5
전체 시간: 127
