Someone on the Sony forum found the solution:
1- Remove the battery and unplug from the power source
2- leave the radio without battery and power for a minute or two
3- while pressing the ALARM RESET button conect to the power souce but do not install the battery
4- keep pressing the ALARM RESET button for another minute after pluging to the power outlet
5- Release the button, wait 5 seconds then set the radio according to your preference
6- after you are done setting the radio, re-install the battery
7- (Optional) if step # 3 doesnt work, press ALARM RESET and SLEEP buttons at the same time (you will see all the LED's turning on in the screen, and wont turn off until you remove the power source), unplug the radio, then proced to step #3
you should be good to go if you follow these steps.
Here's the link to it:
https://community.sony.com/t5/Other-Prod...
댓글 12개
Did you manage to work this out its happening to me??
Allan Steven 의
Had one with this problem just 15min after unpack.
Replaced, and the new one has same problems randomly once 1 or 2 months but removing battery and AC normally solves the problem.
Andrea Campiotti 의
a complete scandal to sony leaving a defective product to be sold and its authorizeds say that they can not do anything, that they laminate. i thinking quality sony be placed in the trash.
Claudio Diniz 의
It worked ok during 6/7 months and all of a sudden the projector didn't work nor any button. After replacing the backup battery the unit keeps having the 0:00 time flashing for ever. I have tried multiple buttons sequence but didn't find the right combination yet. If a genius could help, I nearly convince that this is a software problem not a hardware fault. ANY IDEA ???
Fabrice Vuillemenot 의
Has anyone ever been able to find the fault on these units? I have a dvb version very similar with must of buttons not working. Opened up cleaned and checked for any visual problem but looked ok. Put back together still same problem. Any genius out there? Thnx
Gimi Tryci 의
댓글 7개 더보기
