주요 콘텐츠로 건너뛰기
Quad Core 9 inch Android enabled Tablet, released October 2014, identified by model number ME-9Q
14 질문 전체 보기
Why is my front facing camera not working?
Whenever I go to take a picture the camera shows a black screen. I've tried factory resetting the device with no avail. Do I need to replace the camera or is it unfix-able?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
First be sure that the lenses view isn't obstructed by any foreign objects, i.e. fingerprints, dust, etc. Also be sure that the lighting is adequate. If this doesn't help you may need get inside the tablet. When you take it apart be sure that the camera's cable is plugged in all the way; otherwise, replace the camera.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
As a last before replacing the camera module, try to do a factory reset. Sometimes, more often than not, there may be a software glitch that will cause the camera module drivers to operate improperly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Joseph Justice 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 116
