주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Replaced Battery, the flash isn´t working and screen wont rotate
So today I replaced the battery of my Iphone 6, as soon as I changed it a couple of short vertical lines apeared at the top of the display, but after 30 minutes of use the lines dissapeared on their own, but now I tried to take a photo with flash and it isnt working, I tried restarting the phone twice, doing a hard reset and checked again that everything inside was correctly pluged in, and everything seemed good. Also the screen wont rotate, all setting are enabled for rotation but it doesnt rotate. What could be causing this and how could I repair it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Wouldn’t be surprised the power button/flash led flat cable got damaged during battery replacement as it runs right under the battery and it’s a delicate part. I’m a bit surprised about rotation as that depends on the gyro which shouldn’t have been affected at all, maybe a related issue although uncommon. I’d definitely replace the cable to start with, you can get references from the following guide: iPhone 6 Power Button Cable Assembly Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Are you sure of the branding of the battery you have replaced? Get an original one. The lines on your screen are the extra voltage received by your iPhone.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 1개:
I realized I just answered a question asked 2 years ago as it was pulled back from oblivion. I don't see very much point in wasting time answering to such old questions..one way or the other the issue was overcome long time ago undoubtedly.
댓글 달기
귀하의 답변을 추가하세요
Manuel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 77
