주요 콘텐츠로 건너뛰기
발표 - 2014년 11월 Samsung Galaxy Core Prime (G360, G361)은 1.3GHz quad-core 프로세서로 작동하며 1GB RAM을 제공합니다. 휴대폰은 8GB 내부 저장 용량을 제공하며 microSD 카드를 사용하여 최대 64GB까지 확장할 수 있습니다.
67 질문 전체 보기
My phone does not turn on
My phone read T-Mobile update available when I tried to update the phone it says update failed at 92% now the phone won't turn on. When I press the power button it vibrates and shows the Samsung Galaxy Core Prime powered by android screen and is stuck there.
I am located in the Caribbean at the moment.
Can you help me with this problem I have only had the phone for about 6 months
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
I would try to clear the cache partition in recovery mode. To do this you first need to boot the phone in recovery mode.
Press the Power, Home, and Volume up buttons at the same time.
Release all key when Android or Samsung logo appear then you will see Android System Recovery.
Navigate with the volume keys, and select with the power button.
Navigate to wipe cache partition, and select it.
Wait for that to finish, then reboot your phone.
Hope that helps :)
If it doesn't work though, i would do a factory reset using the same method, unless anyone else has a better answer. (The factory reset will erase ALL personal data from your phone. So it should be a last ditch effort.)
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I have the same problem too, but it didn't work. Although my updates didn't fail, but my phone ran out of battery and shutdown and i cant turn it back on again, have any ideas?
i just bought the same phone today it is just turning on and off continuously
please help
댓글 달기
If also not solved your problem try to change volume keys
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
candyluvcall411 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 2,045
