주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
How to fix iPhone that fell in fuel.
So i was working one day at the fuel pits and my phone fell into a bucket full of fuel. I quickly grabbed it, wipped my phone off and shut it off due to fear of explosion. I turned it on the next day and phone works perfectly fine but the screen is dark and you can still see the fuel underneath the screen. Nothing was damaged suprisingly. Im just wondering how would i get the fuel out!? dark screen sucks and i have to use the brightness all the way up in order to see
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Dropped my phone inside petrol fuel and it affected the phone camera lens to blurr please what can I do to washed it away or clean that ???
A little petrol entered my phone, and now part of the phone is affected but it's still working perfectly well, what am I going to do to remove the remaining petrol
댓글 달기
답변 5개
선택된 답변
First of all, NEVER USE RICE. Rice does nothing. Take the phone apart, remove the LCD assembly, battery, and logic board. Put the housing and logic board in 91% isopropyl alcohol and get a new battery. Take apart the LCD backlights and clean them in isopropyl. Dry them very good and then put everything back together.
해당 답변은 도움이 되었습니까?
점수 3
댓글 6개:
This worked! thanks alot.. had to get some tools that i didnt have but it did the trick!
I guess you are pretty lucky to get the fuel out of the backlight area which is located behind the LCD, because that can be hard to get out at times without damaging the display or backlight.
no need to shout!! next time have one of these handy in your pocket [연계 제품이 누락 또는 비활성화 됨: IF145-163-3]
so my phone fell into a bucket of fuel today but I have a iPhone xr now theres fuel behind the screen and can't get it out
What if the battery is an in-built
How can I get it out
댓글 1개 더보기
댓글 달기
I also dropped my phone in gas. It is a LG k20 plus. It was in a minute before we realized it and it was acting totally normal as far as I could see. It rang and lit up (how it was found in the dark) and after 30 min stitting still rang and lit up. I only used the fingerprint reader to see if it would wake up and to close the memo pad which likes to open itself a lot which went to the lock screen. The display looked fine for me. Just wanting to ask if I should try the same fix as with the original phone in this thread. And any advise.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
تسرب بعض البنزين (البترول) الى شاشه جهازي الاندرويد والان يوجد بقع بيضاء مضيئه في الشاشه وخط يقرب للون الاصفر اسفل الشاشه
هل يمكن حل لهذه المشكله لو سمحتم
댓글 달기
My laptop fell in turpentine please what should I do
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
what about if it is non removable battery?..what should i do?…also, is it safe to charge the mobile phone even if it still smells gasoline?..pls do reply..thanks a lot
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
turn phone off, remove battery, and use 80 -100% alcohol (available from chemist, not the pub) pour over the alcohol gently and in stages, this should flush out the fuel and the alcohol will eventually evaporate.
if this does´nt work buy new display, remove old display, use the alcohol to clean the the inside out, wait till its clean and dry, fit new screen. and all been well iphone works a treat again
해당 답변은 도움이 되었습니까?
점수 -2
댓글 1개:
@howie77 rice? Really? No way. Review your answer and reconsider the rice part.
댓글 달기
귀하의 답변을 추가하세요
Jason Navarrete 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 50
30일 전: 214
전체 시간: 14,301
