주요 콘텐츠로 건너뛰기
Repair information for the Asus VivoBook S551LB laptop. First available on Amazon in July of 2013. Model number: V551LB-DB71T.
13 질문 전체 보기
resting to factory sttings
haw can get factory setting for my asus
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
If it's not an old model then you have a recovery partition, so with Asus you shut down your computer. After you turn it back on hit the F9 key right after you release the power button.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Many viruses will damage the recovery partition, and it will still require a password to do the reset in windows 8 and 10. A clean install is always best
댓글 달기
Re-Install windows by getting the correct iso (make sure it is untouched, no crack or piracy) and putting it on a usb with rufus.akeo.ie and then boot from that usb by pressing esc repeatedly while booting and selecting it.
Delete all partitions when installing windows and let it create the necessary system partitions again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
alrashed doura 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 378
