주요 콘텐츠로 건너뛰기
Inexpensive 5 1/4" 4G LTE 2016 phone. Fixed battery, 2 SIMs, up to 64GB microSD.
40 질문 전체 보기
blu life one x not charging
blu life one x has stopped charging...tried charging from a laptop, have tried multable charging cables...what should i do next?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 1개
I can't find a battery replacement for this phone,; not longer available for this model so I can't recommend it. I had to buy a new phone, (Motorola).
댓글 달기
답변 3개
가장 유용한 답변
Sent mine back to the shop, battery would show a percentage ie: 16% regardless if charged or not, and would never change untess unplugged, plugged back in, then it would show ie: 100% and never change... ...Sent it back with phone back cover (minus the battery and sdcard) they sent Me a new one the battery charged discharged just fine, and displayed properly... All was ok then...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
how do you contact their uk support centres - I bought mine from amazon uk?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The daughter board for charging is easily replaceable if it's damaged. The battery itself is glued on, but if it's bad you can easily pry it off and throw it away once it's discharged, replacements should be available on ebay.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
My Blu life one x2 is not taking a charge and I don't know what to do.
Do I need a new phone?
댓글 달기
귀하의 답변을 추가하세요
gascaps 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 3,313
