주요 콘텐츠로 건너뛰기
Apple Macintosh 개인용 컴퓨터 수리 안내서 및 분해 정보입니다.
42809 질문 전체 보기
How do I reset the open firmware password on my Mac?
My iBook shows a padlock, entry area and an arrow pointing to the right. Any idea on what a password should be? This showed up after putting the hard drive out of a iBook g4 into an iBook. Should other components have been switched as well. Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 3개
Is this right after you turn it on, or after it boots into the operating system?
Here's to info you want Majesty. Ralph http://support.apple.com/kb/HT1352
rj713, 9 hours ago • Delete
Does this also work for an 2012 iMac?
댓글 달기
답변 9개
선택된 답변
Hi! This machine has an open firmware password enabled, which is similar to a BIOS password on a PC. This is not the same as the admin password, i.e. it's in the firmware of the machine itself, and not something on the hard drive.
Basically, this means that a previous owner of the machine decided to lock it, and this lock will prevent you from booting to other drives, optical media, etc. If you know the password, you can go into open firmware and disable the lock. Otherwise, there is a procedure to override it: You need to change the amount of RAM in the machine (either add memory or remove existing memory in the expansion slot), and IMMEDIATELY, i.e. the first time booting after changing the RAM, reset the PRAM three times in a row. That means it needs to chime three times after the power-on chime. Once you've done this, you should no longer see the lock. It's Apple's "top secret" way to bypass an open firmware password.
해당 답변은 도움이 되었습니까?
점수 24
댓글 11개:
Wow. That's an awesome answer. Gets my vote!
rdklincorporated, we should not give hints here to bypass firmware password protection. A thief could use it to access private data of a stolen Mac.
If a thief is resourceful enough to bypass an open firmware password, he's also smart enough to remove the hard drive and put it in a USB enclosure in order to access the data (which the open firmware password does not guard against). I think this is common enough of an issue in used Apple laptops that it is critical for refurbishers to know in order to salvage recycled machines. Without this knowledge, a lot of machines are completely worthless and assumed ready for the scrap heap.
I would also add that LOTS of recyclers sell off Apple laptops as "dead" that simply need their passwords bypassed. If they knew how to do this, then they would be able to meet their obligations to delete the data, instead of passing it on to others and risking the data being compromised.
He's done it again :o) Keep'em coming RDKL.++++
By the way, how do I go about setting this type of password on my MacBook???
댓글 6개 더보기
댓글 달기
I went nuts trying everything to get the "reset RAM" trick to work on My 2009 2.66 MacBook Pro, and partly by luck, I finally got the EFI PW to reset.
I had to remove the bottom RAM Piece, and boot it with just only the top positioned RAM in it. . Just removing the top RAM piece was NOT working.
Also if you have only one RAM piece, and dont want to buy another, try repositioning the RAM, into the other RAM position to reset the EFI.
I hope my comments helps someone as much as it would have helped me 2 weeks ago.
BEST !
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
Sorry folks but there is no way to by pass lock screen (EFI) if you have got a new mac (air, book pro, or what ever) since early 2011. The main reazon is that every singel password is saved in to the bios (i know, i know…) well the little chip that serves as a bios (still it is actually a bios) that you have to remove and then get a new flashed one... if you found it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Not certain this is your situation, but you might want to check out the answers to this question for advice on how to get access to an OS X computer if you've forgotten or don't have the administrator password: how do i reset my administrators password?or reset the whole thing?
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Hi guys could you please tell where is RAM locate in Apple MacBook Air 2013? I only found HD but not Ram can someone let me know. Thanks in advance
hi alex ...i have the same problema...you fixed it?
2013 ram is soldered on the Air...you cant remove it. Uf its locked youre stuck there for lufe unless you get the original passcide etc. Theres no back door for this machine like the abive much older ones with removable ram. Its all tied to an Apple ID now as well as filevauot which you cant bypass without proof of ownership like an original receipt with your name or credit card etc. This is to prevent theft and Not even Apple will unlock without "without a doubt proof" that you are the original owner...sorry...youre stuck with it in this status.
댓글 달기
I'm currently struggling with this on a refurb mac mini... I installed XP yesterday and now I can either get to the password/lock screen or just xp... My problem gets worse, my time machine drive is now throwing the click of doom so if I can't get back to my mac side and have to get an os disc (didn't come with os or gray disc) I lose everything, including emails I've been saving since 2002! Ick
Anyone know how much the apple store might charge to "reset" this?
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Please start your own question.
Cassie, apple wont do a thing uf machine is licked if you cant.prove legal ownership. As far as the time capsule it just depends on how bad. Data recovery can be very costly. Youd have tonsimy get to a store or call them and see what they say. Theres no easy ir difinitive answer.ir price.
댓글 달기
thishelped alot .My laptop was under my couch for 8mths.
Thanks
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Dont forget to press the Command - Option - P - R keys together until you hear three chimes then it's reset. Older units have reset buttons located on the unit.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Your solution still bloddy works after all the updates all these years. Excellent tip buddy.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
My MacBook Air 2009 model locked I want unlock for free
Update (01/06/2017)
I need help unlock my laptop MacBook Air 2009 model for free
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Youll never get it unlocked....and certainly not for free....youre stuck with it...
댓글 달기
귀하의 답변을 추가하세요
cathy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 20
전체 시간: 52,274
