주요 콘텐츠로 건너뛰기
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
The LCD brightness is darker on one side after replacing?
i have just replaced the LCD on an ipad 3rd gen. I have completed the repair and now i have noticed that one side is darker in screen brightness to the other side. Why is this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
thanks Josh. i will have a look. i never use tools to disconnect cables. luckily my nails do the trick, but it maybe a screw too tight. Thanks for the info. :)
댓글 달기
답변 1개
선택된 해법
How much darker? Can't read it dark or just annoyingly dark?
If its just a bit darker, it could be as simple as a screw or something else is stuck under the LCD causing it to look funny. If its noticeably darker, then you blew one of the backlight filters. There are 2, one for each side of the screen. Its very common to blow those filters, especially if you used metal tools to disconnect the LCD or digitizer.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Bev 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 2
전체 시간: 122
