주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NX30은 렌즈 교환식 미러리스 카메라입니다. HD 비디오 촬영이 가능하며 2014년 2월 18일에 출시되었습니다.
Lens will not focus
Hi!
I got this camera three months ago and very satisfied with picture quality. Recently, I noticed that 55 mm lens that came with the camera stopped focusing. It will focus only on 45 mm, but not on 18mm. I tried changing settings from manual focus and back. Took the lens off and put it back.
Thanks,
Maria
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Maria, I have had a similar problem (with a different camera/lens). I have noted two possible causes. First is in low light or low contrast. It seems that especially with low contrast, it depends on having a focal length that includes enough variation in contrast in the auto focus region. Two ways to potentially handle this. Once you have found a focal length you can focus at, hold the shutter down 1/2 way down, then change the focal length of the lens. OR - change the AF focus method to, say, center weighting.
The other thing I have noticed is sometimes the battery indicator say everything is okay, but it is not sufficient for focusing under these low light/contrast conditions. Changing/recharging the battery has often resolved the problem.
Hope it helps.
Mike
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mashahunter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 38
전체 시간: 637
