Not turning on after power jack replacement.
I originally found this at a Flea Market, and had to replace the power jack on it. When I installed the new power jack, I accidentally cold worked the upper lead until it came off - the lead from the old jack was still intact, so I was able to replace that as well. When I went to test it though, the screen was black with some white flickering, before it went completely black, with no power light turned on. I've checked the Fuse, and the Fuse is able to to pass a continuity test. I'm confused at this point, since the fuse is the only thing I can think of that could be preventing it from turning on, especially with the power light off. Any suggestions? Could the polarity be getting mixed up somehow? I did have to remove the RF module temporarily in order to get the power jack on.
Any help would be appreciated.
Edited 8-28-2016: The Power light does turn on when the switch is on - I took it to the local professional tech, and he thinks I may have accidentally fried something when I removed the RF module to put on the power jack. (apparently you can bend the RF module to some extent without desoldering it in order to fit on the new backplate/power jack.) He tried using a different RF module, Power Jack, and Voltage Regulator (if I'm remembering correctly) with no response. When I test it, I put in the cartridge, turn it on, and nothing appears on screen.
좋은 질문 입니까?
댓글 3개
@supportninja post some images of what you repaired so we can see what you see. Sounds like you ran into a few issues....
Rep: 201
oldturkey03 의
I'll see if I can open it up again tomorrow to take some pictures.
Ben Eccles 의
Picture added - I'm tempted to redo the joints, since I think my iron was too hot. I soldered the Power Jack, and resoldered the RF Module after I removed it to put on the new jack.
Ben Eccles 의
