주요 콘텐츠로 건너뛰기
Repair guides and support for tablets manufactured by Azend/Envizen.
How do I do a hard reset on my tablet
how do i do a hard reset
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 11
댓글 13개
how do i do a hard reset on my tablet
My tablet wont turn on even when i leave it to charge for hours what do i do?
I have a Envizen tablet,ive already rest it a couple of times and when I turn it on nothing seems to happpen
i bought this tablet from hsn .i tried to reset. its not in english when i try to reboot it thank you
I tried to do a factory reset on my Envizen tablet. It keeps getting stuck where it says insert sim card it won't let me skip this step .Ive pushed skip several times without it doing anything. Help!
댓글 8개 더보기
댓글 달기
답변 2개
선택된 해법
although I have not done an Envizen tablet most android tablets are the same in there hard resets . first check to see if there happens to be a reset button anywhere on the tablet .
If not,First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button. Go to the option for Factory Data Reset and select it. Scroll down to `the Yes, and then the tablet will erase its memory back to factory settings. Once it has completed, select Reboot Tablet Normally. Remember when you do a factory reset you lose all data and it will be like the day you started it for the first time all apps photos, music, addresses and phone numbers will be gone so back that up before you do this . Hope this helps
이 답변이 도움이 되었나요?
점수 9
댓글 15개:
This was easily understood and instruction clear.it saved my day
mine shows a picture of the android guy on his back with a red triangle over his open stomach! what does that mean?
Greetings,
I h ave an Envizon EVT10Q tablet bought from a reputable source on Ebay. have tried several times to factory reset to no avail. Each time I go through the process and try to sign in withe my own Google account, I am asked to use the address originally synced to the tablet . I have tried using drfone to no avail. My PC doesn't want to recognize the tablet either. Please help if you can. Thank youi.
Robert have you tried to wipe the cache partition instead of doing the factory reset. you may need to get a clean boot to get things rolling
댓글 10개 더보기
댓글 달기
I don’t know
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
john12708 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 34
전체 시간: 16,404
