주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Full washing machine cycle salvage?
Co worker put IPhone 5s through full cycle with IPhone on. I've placed it in rice, should get the screwdrivers to open the phone come Tuesday and i'll take it apart and place it in rice for another few days. Placing the new battery I'm buying. Any take on if this is salvageable and if the battery doesn't work, how do I check logic board?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Rice does not do anything for your waterlogged phone except let the water sit longer which causes further oxidation. What you should do instead is take the phone apart. Disconnect the battery and remove all of the components from the logic boards. Remove the covers from the logic boards, as they hold in the water, and run them through a good ultrasonic cleaner for 20 minutes. When finished, submerge the logic boards in 99% iso alcohol for a few minutes to displace the water. Let these dry completely. That should stop the oxidation which is what will cause further damage.
As for the damage that the water is done, it may be too expensive to fix. There are a few companies that can look at the logic boards and make that determination or possibly recover your data.
Good luck and avoid the Rice
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Joe Eimert 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 68
