Replacing Capacitor with a slightly less capacitance
My old Candy Microwave has a 1.2uF 2100V Capacitor. I could not find a replacement with the same capacitance, but only one with 1.14 uF 2100V. Would it be OK to replace with that one?
좋은 질문 입니까?
좋은 질문 입니까?
The value of the capacitor is not that critical, it does not effect the resonant frequency of the magnetron. Using that capacitor will give you slightly less power but you wont notice the difference. The voltage rating should be at least as much as the origional capacitor. I repaired Microwave ovens for 30 years.
해당 답변은 도움이 되었습니까?
well, I have a similar issue. the original capacitor was 1MFD, but on testing the capacitance of a replacement part, it shows 0.6 MFD, almost half. will this work ?
replaced the diode, magnetron cold test ok, replaced with a new one, didn't work so put back the original one.
Help me I was fixing a defy microwave this what happened at first it was blowing fuse so I changed one of the diode which was not OK but still it continued to blow so I changed a capacitor and display was off I tried to replace the one which was at first and its fun and bulb its working when the door is open I have checked switch's they are OK.help me
My case is a bit different, my old capacitor is 0.8uf 2000V, can i replace it with 0.85uf 2100v? im having a bit trouble finding the same specs as the old one. thanks in advance
certainly not! voltage has to remain the same as original. if 2000V , then keep it the same, but as for uF frequency anything within a 10-20 % increase of original is fine. jus replaced my 0.85uF capacitotor with a 0.9uF capacator, and works great. keep in mind the diode has to match the capacator. hope this was helpful.
That 1.2 uf cap is in a tuned circuit (with inductor) which has to do with frequency and should be replaced with same value. The replacement will probably work since values of components will change slightly over time but I would still stick to the original value.
해당 답변은 도움이 되었습니까?
No, you need to use one that has the same specs as the old one. You should be able to find one online with the model number that's on the old one, or perhaps contacting the manufacturer for the part number. Circuits are designed with certain specs, that if altered, could cause poor performance (not as much power as before) or burn something else out. Digi-key is a good place to look for electronic parts too.
해당 답변은 도움이 되었습니까?
Can you get the correct one from Mouser Electronics? http://www.mouser.com
Personally, being that it is a microwave I would have no problem changing it out with that cap. 0.06uF should be within tolerance. Worst case you may be putting additional wear on something else down the line.
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 18
30일 전: 80
전체 시간: 10,697
댓글 1개
If you are within 5 to 10 % you will most certainly be fine. You will never find anyone who had a problem using a capacitor that was 0.05 uF different from the original. But certainly don't push it past 20%.
Despite some other comments, the capacitor is NOT part of any tuned oscillator working in conjunction with the magnetron. The magnetron is a self contained oscillator.
timblake2112 의
