주요 콘텐츠로 건너뛰기
The TI-84 Plus Silver Edition is a graphing calculator released in 2004. It includes a USB port, pre-loaded software, APPS, storage, and a removable front and back case.
How to turn on newly bought TI-84 Plus Calculator?
My aunt recently bought me a new TI-84 Plus for college and after opening the package and inserting all of the batteries I can't seem to figure out how to turn the calculator on. I've tried simply pressing and holding the ON button & taking the batteries out and putting them back in. I've also hooked it up to the USB cable that came with it, but after 15 minutes of charging nothing seemed to happen. Am I doing something wrong or forgetting something? Do I just need to let it charge more or is there some software I need to download or something? Thanks to everyone in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
Wow, I'm late.
Try plugging the calculator into your laptop. This should make it turn on if the [on] key doesn't work.
You could also try turning it on, then press [2nd] then hold down the up arrow until you see a cursor flashing. If it's been 10 seconds and you don't see anything that's not good.
Try removing the backup battery (and replacing it) and one of the AAA batteries. Then wait 10 minutes, then replace the backup battery and AAA battery. This should force the calculator to turn on.
If nothing worked, then it sounds like you have a defective calculator. :\
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tyler Nelson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 11,202
